TDengine columnDataExecuteBatch() (0x230):Stmt cache error 翻官网翻烂了没找到
3.3.6 / maven taos-jdbcdriver驱动3.7.4/3.8.3/3.9.0 都试验过了
jdbc-ws连接方式,columnDataExecuteBatch/ executeBatch方法批量插入的时候全部都是
java.sql.SQLException: TDengine ERROR (0x230): (0x230):Stmt cache error
at com.taosdata.jdbc.TSDBError.createSQLException(TSDBError.java:102)
at com.taosdata.jdbc.ws.AbsWSPreparedStatement.executeBatchImpl(AbsWSPreparedStatement.java:1129)
at com.taosdata.jdbc.ws.AbsWSPreparedStatement.columnDataExecuteBatch(AbsWSPreparedStatement.java:1144)
官网chat对话问了找不到原因,文档目前没有找到
addBatch + executeBatch:
public void newBatchInsertStmt2One(List dataList) throws SQLException {
String sql = "INSERT INTO ? USING st_cm_monitor_data " +
"TAGS(?,?,?,?,?,?,?,?) " +
“VALUES(?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?,?)”;
List<MonitorDataEntity> list = dataList.stream().map(this::convert).collect(Collectors.toList());
Map<String, List<MonitorDataEntity>> tableGroup = list.stream()
        .collect(Collectors.groupingBy(MonitorDataEntity::getMonitorCommonCode));
Properties props = new Properties();
props.setProperty(TSDBDriver.PROPERTY_KEY_USER, username);
props.setProperty(TSDBDriver.PROPERTY_KEY_PASSWORD, password);
props.setProperty("stmtBindMode", "traditional");
try (Connection conn = DriverManager.getConnection(url, props)) {
    for (Map.Entry<String, List<MonitorDataEntity>> entry : tableGroup.entrySet()) {
        String tbName = entry.getKey();
        List<MonitorDataEntity> itemList = entry.getValue();
        if (itemList.isEmpty()) continue;
        try (TSWSPreparedStatement stmt =
                     conn.prepareStatement(sql).unwrap(TSWSPreparedStatement.class)) {
            stmt.setTableName(tbName);
            for (MonitorDataEntity item : itemList) {
                // ---- 标签:索引从 1 开始 ----
                stmt.setTagString(0, item.getMonitorCommonCode());
                stmt.setTagLong(1, item.getStationId());
                stmt.setTagString(2, item.getDeviceLargeType());
                stmt.setTagString(3, item.getDeviceTypeCode());
                stmt.setTagInt(4, item.getMonitorType());
                stmt.setTagString(5, item.getMonitorTypeCode());
                stmt.setTagLong(6, item.getDeviceId());
                stmt.setTagLong(7, item.getMonitorDeviceId());
                // ---- VALUES 列:索引从 1 开始 ----
                stmt.setTimestamp(1, new Timestamp(item.getCollectionTime().getTime()));
                stmt.setBigDecimal(2, item.getCurrentValue());
                stmt.setBigDecimal(3, item.getMinusValue());
                stmt.setInt(4, item.getDataSource());
                stmt.setInt(5, item.getDataStatus());
                stmt.setInt(6, item.getDataType());
                stmt.setString(7, item.getAncestors());
                stmt.setString(8, item.getDeptAncestors());
                stmt.setLong(9, item.getDeptId());
                stmt.setString(10, item.getDeptName());
                stmt.setString(11, item.getDeviceCode());
                stmt.setString(12, item.getDeviceName());
                stmt.setString(13, item.getDeviceLargeTypeName());
                stmt.setLong(14, item.getLineId());
                stmt.setString(15, item.getLineName());
                stmt.setString(16, item.getMonitorDescription());
                stmt.setString(17, item.getMonitorTypeName());
                stmt.setString(18, item.getRegisterNumber());
                stmt.setString(19, item.getUnit());
                stmt.setTimestamp(20, new Timestamp(item.getCreateTime().getTime()));
                stmt.setInt(21, item.getCreateBy());
                stmt.addBatch();   // ← 标准 JDBC 行模式
            stmt.executeBatch();  // ← 标准 JDBC 批量执行
columeData方式:
public void newBatchInsertStmt2(List dataList) throws SQLException{
String sql = "INSERT INTO ? USING st_cm_monitor_data_bak " +
// 分组key建议直接是子表名称,这里先用你原有分组逻辑
Map<String, List> tableGroup = list.stream()
        // 遍历每一个子表分组
            // 每个子表独立创建stmt,try自动关闭,彻底清除缓冲区残留
            try (TSWSPreparedStatement stmt = conn.prepareStatement(sql).unwrap(TSWSPreparedStatement.class)) {
                // 先固定子表名,全程不变
                MonitorDataEntity itemCase = itemList.get(0);
                // 逐个TAG单值赋值(官方原生存在的方法,不会爆红)
                stmt.setTagString(0, itemCase.getMonitorCommonCode());
                stmt.setTagLong(1, itemCase.getStationId());
                stmt.setTagString(2, itemCase.getDeviceLargeType());
                stmt.setTagString(3, itemCase.getDeviceTypeCode());
                stmt.setTagInt(4, itemCase.getMonitorType());
                stmt.setTagString(5, itemCase.getMonitorTypeCode());
                stmt.setTagLong(6, itemCase.getDeviceId());
                stmt.setTagLong(7, itemCase.getMonitorDeviceId());
                List<Long> list0 = new ArrayList<>();
                List<Double> list1 = new ArrayList<>();
                List<Double> list2 = new ArrayList<>();
                List<Integer> list3 = new ArrayList<>();
                List<Integer> list4 = new ArrayList<>();
                List<Integer> list5 = new ArrayList<>();
                List<String> list6 = new ArrayList<>();
                List<String> list7 = new ArrayList<>();
                List<Long> list8 = new ArrayList<>();
                List<String> list9 = new ArrayList<>();
                List<String> list10 = new ArrayList<>();
                List<String> list11 = new ArrayList<>();
                List<String> list12 = new ArrayList<>();
                List<Long> list13 = new ArrayList<>();
                List<String> list14 = new ArrayList<>();
                List<String> list15 = new ArrayList<>();
                List<String> list16 = new ArrayList<>();
                List<String> list17 = new ArrayList<>();
                List<String> list18 = new ArrayList<>();
                List<Long> list19 = new ArrayList<>();
                List<Integer> list20 = new ArrayList<>();
                    list0.add(item.getCollectionTime().getTime());
                    list1.add(item.getCurrentValue() != null ? item.getCurrentValue().doubleValue() : null);
                    list2.add(item.getMinusValue() != null ? item.getMinusValue().doubleValue() : null);
                    list3.add(item.getDataSource());
                    list4.add(item.getDataStatus());
                    list5.add(item.getDataType());
                    list6.add(item.getAncestors());
                    list7.add(item.getDeptAncestors());
                    list8.add(item.getDeptId());
                    list9.add(item.getDeptName());
                    list10.add(item.getDeviceCode());
                    list11.add(item.getDeviceName());
                    list12.add(item.getDeviceLargeTypeName());
                    list13.add(item.getLineId());
                    list14.add(item.getLineName());
                    list15.add(item.getMonitorDescription());
                    list16.add(item.getMonitorTypeName());
                    list17.add(item.getRegisterNumber());
                    list18.add(item.getUnit());
                    list19.add(item.getCreateTime().getTime());
                    list20.add(item.getCreateBy());
                    // 单行加入批次
                stmt.setTimestamp(0, list0);
                stmt.setDouble( 1, list1);
                stmt.setDouble( 2, list2);
                stmt.setInt( 3, list3);
                stmt.setInt( 4, list4);
                stmt.setInt( 5, list5);
                stmt.setString( 6, list6, 64);
                stmt.setString( 7, list7, 256);
                stmt.setLong( 8, list8);
                stmt.setString( 9, list9, 128);
                stmt.setString( 10, list10, 128);
                stmt.setString( 11, list11, 256);
                stmt.setString( 12, list12, 128);
                stmt.setLong( 13, list13);
                stmt.setString( 14, list14, 128);
                stmt.setString( 15, list15, 512);
                stmt.setString( 16, list16, 128);
                stmt.setString( 17, list17, 32);
                stmt.setString( 18, list18, 16);
                stmt.setTimestamp( 19, list19);
                stmt.setInt( 20, list20);
                stmt.columnDataAddBatch();
                // 当前子表所有行一次性提交
                stmt.columnDataExecuteBatch();
均报错
解决办法
JDBC 驱动降到 3.3.8,和你 3.3.6 的服务端匹配:
<dependency>
    <groupId>com.taosdata.jdbc</groupId>
    <artifactId>taos-jdbcdriver</artifactId>
    <version>3.3.8</version>
</dependency>
3.3.8 的 JDBC 驱动支持 columnDataExecuteBatch 吗?支持。它是 3.3.x 系列的最新版,包含了该功能且协议与 3.3.6 服务端兼容。
