3.3.6.9版本 interval 时间窗口查询数据有误
ubuntu 24
单机
单机
按时间窗口查询,出现阻塞和数据出错情况。场景是景是查询电表一年内12个月的耗能情况(查询当月每天也是如此)
  1. 通过 INTERVAL(1n ,AUTO ),返回了13条数据,时间戳为每个月2号0点,且都是null。
  2. 返回值加上id ,查询进程阻塞。
  3. 返回值加上id,通过 INTERVAL(1n), 可以正常返回,但是返回的数据也为13条,但返回时间戳为每月1号,8点。
好的 我们本地先验证一下。
超级表结构:CREATE STABLE IF NOT EXISTS s_pulse (ts TIMESTAMP, val DOUBLE , prop INT) TAGS (id INT ,factory_id INT ,equip_id INT);
sql:
  1. select _wstart as ts , (last(val) - first(val)) as val from jlbk.s_pulse
    where id in ( 1434 ) and ts >= “2025-01-01 00:00:00.0” AND ts < “2026-01-01 00:00:00.0” partition by id INTERVAL(1n ,AUTO ) fill(null);
  2. select _wstart as ts , (last(val) - first(val)) as val, id, first(factory_id) as factory_id, first(equip_id) as equip_id, first(prop) as prop from jlbk.s_pulse
  3. select _wstart as ts , (last(val) - first(val)) as val, id, first(factory_id) as factory_id, first(equip_id) as equip_id, first(prop) as prop from jlbk.s_pulse
    where id in ( 1434 ) and ts >= “2025-01-01 00:00:00.0” AND ts < “2026-01-01 00:00:00.0” partition by id INTERVAL(1n) fill(null);
本地验证无误,需要进一步排查
