docker 3.3.7.5
windwos 11
docker
不知道问什么,容器启动后6060打不开,看docker的log如下:
2025-09-27 19:35:55.942 | 09/27 11:35:55.942285 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.942 | 09/27 11:35:55.942572 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.942 | 09/27 11:35:55.942870 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.943 | 09/27 11:35:55.943210 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.943 | 09/27 11:35:55.943570 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.944 | 09/27 11:35:55.943881 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.944 | 09/27 11:35:55.944214 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.944 | 09/27 11:35:55.944504 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.944 | 09/27 11:35:55.944776 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.945 | 09/27 11:35:55.945050 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.945 | 09/27 11:35:55.945338 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.945 | 09/27 11:35:55.945639 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.946 | 09/27 11:35:55.946059 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.946 | 09/27 11:35:55.946447 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.947 | 09/27 11:35:55.946873 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.947 | 09/27 11:35:55.947216 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.947 | 09/27 11:35:55.947632 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.948 | 09/27 11:35:55.947925 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
2025-09-27 19:35:55.948 | 09/27 11:35:55.948217 00000115 C WAL WARN vgId:2, failed to validate checksum of wal entry header, offset:16764691, file:/var/lib/taos/vnode/vnode2/wal/00000000000000025828.log
一直正常使用,完全不确定哪次关机重启后就出现了,弄好几次了,都是删了重新装,现在项目马上上线了,又出这问题,什么情况?怎么解决?
