基于Mybatis执行动态建表操作,频繁出现 Conflict transaction not completed
Ubuntu 20.04.3 LTS
建库语句:CREATE DATABASE IF NOT EXISTS pm_kpi KEEP 180 DURATION 10 BUFFER 16 WAL_LEVEL 1;
插入数据前的建表操作频繁失败
定期自动插入数据前,自动检查表是否存在,不存在则自动创建超级表和子表
插入数据前的建表操作频繁失败,单次执行都是正常,貌似并发时才频繁出现
spring:
tdengine:
url: jdbc:TAOS-RS://${AIUMS_TAOS_ADDR:127.0.0.1:6041}/pm_kpi?charset=UTF-8&locale=en_US.UTF-8&timezone=UTC-8
username: ${AIUMS_TAOS_USER_NAME:root}
password: ${AIUMS_TAOS_PASSWORD:AIUMSDB@123456}
driver-class-name: com.taosdata.jdbc.rs.RestfulDriver
hikari:
auto-commit: true
minimum-idle: 10
maximum-pool-size: 10
connection-timeout: 10000
idle-timeout: 10
max-lifetime: 3600
connection-test-query: SELECT 1
异常日志:
2025-07-08T16:03:01.731+08:00 [ERROR] [192.168.30.80] [ailink-pm] [PmFileParserThread-3] c.ailink.pm.handlers.AbstractNrTr069PmFileHandler [183] - parse pm xml file exception, xmlFileName:/var/lib/http-file-server/files/kpi/bbu/1/A_NR_20250708.1115 0800-1120 0800_48BF74.1202000534228JB0008-NR.xml, exception:
org.springframework.jdbc.UncategorizedSQLException:
Error updating database. Cause: java.sql.SQLException: TDengine ERROR (3d3): sql: CREATE STABLE IF NOT EXISTS pm_kpi.s_measdata_bcb_nbs3927d_ho_switch_slice
        start_time TIMESTAMP
        end_time TIMESTAMP
        frequency INT
        ho_attoutexecinterfreqslice INT
        ho_attoutpreintrasysslice INT
        ho_succoutinterfreqslice INT
     TAGS
        ne_id INT
        mo_id VARCHAR(32)
        moi_id VARCHAR(128)
     );, desc: Conflict transaction not completed
The error may exist in URL [jar:file:/data/ailink-pm.jar!/BOOT-INF/classes!/com/ailink/pm/mapper/tdengine/TdengineKpiMapper.xml]
The error may involve com.ailink.pm.mapper.tdengine.TdengineKpiMapper.createSuperTable-Inline
The error occurred while setting parameters
SQL: CREATE STABLE IF NOT EXISTS pm_kpi.s_measdata_bcb_nbs3927d_ho_switch_slice ( start_time TIMESTAMP , end_time TIMESTAMP , frequency INT , ho_attoutexecinterfreqslice INT , ho_attoutpreintrasysslice INT , ho_succoutinterfreqslice INT ) TAGS ( ne_id INT , mo_id VARCHAR(32) , moi_id VARCHAR(128) );
        end_time TIMESTAMP
        frequency INT
     TAGS
        ne_id INT
        mo_id VARCHAR(32)
        moi_id VARCHAR(128)
; uncategorized SQLException; SQL state ; error code [979]; TDengine ERROR (3d3): sql: CREATE STABLE IF NOT EXISTS pm_kpi.s_measdata_bcb_nbs3927d_ho_switch_slice
end_time TIMESTAMP
frequency INT
TAGS
ne_id INT
mo_id VARCHAR(32)
moi_id VARCHAR(128)
);, desc: Conflict transaction not completed; nested exception is java.sql.SQLException: TDengine ERROR (3d3): sql: CREATE STABLE IF NOT EXISTS pm_kpi.s_measdata_bcb_nbs3927d_ho_switch_slice
end_time TIMESTAMP
frequency INT
TAGS
ne_id INT
mo_id VARCHAR(32)
moi_id VARCHAR(128)
at org.mybatis.spring.MyBatisExceptionTranslator.translateExceptionIfPossible(MyBatisExceptionTranslator.java:93)
at org.mybatis.spring.SqlSessionTemplate$SqlSessionInterceptor.invoke(SqlSessionTemplate.java:439)
at com.sun.proxy.$Proxy149.update(Unknown Source)
at org.mybatis.spring.SqlSessionTemplate.update(SqlSessionTemplate.java:288)
at com.baomidou.mybatisplus.core.override.MybatisMapperMethod.execute(MybatisMapperMethod.java:64)
at com.baomidou.mybatisplus.core.override.MybatisMapperProxy$PlainMethodInvoker.invoke(MybatisMapperProxy.java:152)
at com.baomidou.mybatisplus.core.override.MybatisMapperProxy.invoke(MybatisMapperProxy.java:89)
at com.sun.proxy.$Proxy184.createSuperTable(Unknown Source)
at com.ailink.pm.service.impl.PmMuDataServiceImpl.checkAndCreateTable(PmMuDataServiceImpl.java:259)
at com.ailink.pm.handlers.AbstractNrTr069PmFileHandler.autonomousTransferComplete(AbstractNrTr069PmFileHandler.java:167)
at com.ailink.pm.handlers.NrTr069PmFileCompositeHandlerImpl.autonomousTransferComplete(NrTr069PmFileCompositeHandlerImpl.java:66)
at com.ailink.pm.task.pm.HistoryPmFileProcessor.processPmFiles(HistoryPmFileProcessor.java:114)
at com.ailink.pm.task.pm.HistoryPmFileParseTask.run(HistoryPmFileParseTask.java:31)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:750)
Caused by: java.sql.SQLException: TDengine ERROR (3d3): sql: CREATE STABLE IF NOT EXISTS pm_kpi.s_measdata_bcb_nbs3927d_ho_switch_slice
end_time TIMESTAMP
frequency INT
TAGS
ne_id INT
mo_id VARCHAR(32)
moi_id VARCHAR(128)
at com.taosdata.jdbc.TSDBError.createSQLException(TSDBError.java:76)
at com.taosdata.jdbc.rs.RestfulStatement.execute(RestfulStatement.java:77)
at com.taosdata.jdbc.rs.RestfulPreparedStatement.execute(RestfulPreparedStatement.java:216)
at com.zaxxer.hikari.pool.ProxyPreparedStatement.execute(ProxyPreparedStatement.java:44)
at com.zaxxer.hikari.pool.HikariProxyPreparedStatement.execute(HikariProxyPreparedStatement.java)
at org.apache.ibatis.executor.statement.PreparedStatementHandler.update(PreparedStatementHandler.java:48)
at org.apache.ibatis.executor.statement.RoutingStatementHandler.update(RoutingStatementHandler.java:75)
at sun.reflect.GeneratedMethodAccessor266.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.ibatis.plugin.Plugin.invoke(Plugin.java:61)
at com.sun.proxy.$Proxy237.update(Unknown Source)
at org.apache.ibatis.executor.SimpleExecutor.doUpdate(SimpleExecutor.java:50)
at org.apache.ibatis.executor.BaseExecutor.update(BaseExecutor.java:117)
at org.apache.ibatis.executor.CachingExecutor.update(CachingExecutor.java:76)
at sun.reflect.GeneratedMethodAccessor265.invoke(Unknown Source)
at org.apache.ibatis.plugin.Invocation.proceed(Invocation.java:49)
at com.baomidou.mybatisplus.extension.plugins.MybatisPlusInterceptor.intercept(MybatisPlusInterceptor.java:106)
at org.apache.ibatis.plugin.Plugin.invoke(Plugin.java:59)
at com.sun.proxy.$Proxy236.update(Unknown Source)
at org.apache.ibatis.session.defaults.DefaultSqlSession.update(DefaultSqlSession.java:197)
at sun.reflect.GeneratedMethodAccessor267.invoke(Unknown Source)
at org.mybatis.spring.SqlSessionTemplate$SqlSessionInterceptor.invoke(SqlSessionTemplate.java:425)
… 16 common frames omitted
咱们有大批量的超级表创建工作?
没有大批量,但是数据定期插入多个表,多个线程会并发执行,因为无法在编码期预知表结构,需要在插入前自动检查和动态创建表。
看错误提示,应该时执行DDL前,还有未提交的事务,但是因为我时基于Mybatis 的Mapper对象进行操作,没有显示控制事务,不知道为啥会有未提交的事务
这个事务应该就是建超级表还未完成。
