Pandas.to_sql插入数据报错
ubuntu 2204
无法插入数据
pandas.to_sql 无法插入超级表数据
python库为
taospy>=2.8.6
pandas>=2.3.3
numpy>=2.2.6
客户端为
TDengine-client-3.3.6.13-lite
代码
import re
import warnings
from datetime import datetime
from sqlalchemy.exc import SAWarning
import numpy as np
import pandas as pd
from tqdm import tqdm
from sqlalchemy import create_engine, DateTime, text
from sqlalchemy.types import Integer, Float, TIMESTAMP, String
def create_connection_with_sqlalchemy():
    engine = create_engine(f"taos://root:taosdata@192.168.11.225:6030?timezone=Asia/Shanghai")
    conn = engine.connect()
    return conn
conn = create_connection_with_sqlalchemy()
conn.execute(text("CREATE DATABASE IF NOT EXISTS cq"))
conn.execute(
    text(
        """CREATE STABLE IF NOT EXISTS cq.gas_data (datetime TIMESTAMP,p_t FLOAT,p_c FLOAT,q_export FLOAT,p_export FLOAT,temperature_export FLOAT,q_all FLOAT,open_time INT,close_time INT,status INT) TAGS (gas_no BINARY(64))"""
conn.execute(text("Use cq"))
tmp_df = pd.DataFrame({
    "datetime": [datetime(2025, 7, 7, 8, 5, 40, 465),datetime(2025, 7, 7, 8, 10, 50, 465)],
    "p_t": [1.64, 1.66],
    "p_c": [3.16, 1.34],
    "q_export": [1.3103895, 1.2312],
    "p_export": [1.633, 1.232],
    "temperature_export": [15.53, 4.312],
    "q_all": [167.7261, 254.2],
    "open_time": [120, 120],
    "close_time": [360, 360],
    "status": [1,1],
    "gas_no":['a2','a3']
column_types = {
    'datetime': TIMESTAMP,
    'p_t': Float,
    'p_c': Float,
    'q_export': Float,
    'p_export': Float,
    'temperature_export': Float,
    'q_all': Float,
    'open_time': Integer,
    'close_time': Integer,
    'status': Integer,
    'gas_no': String,
tmp_df.to_sql("gas_data", con=conn,
              index=False, if_exists="append",dtype=column_types)
插入数据报错
添加 tbname
        "datetime": [
            datetime(2025, 7, 7, 8, 10, 50, 465),
        "status": [1, 1],
        "gas_no": ["a2", "a3"],
        "tbname": ["tbname1", "tbname2"],
1 个赞
