Pandas to_sql 方法报错
ubuntu 2204
无法插入数据
pandas.to_sql 无法插入超级表数据
python库为
taospy>=2.8.6
pandas>=2.3.3
numpy>=2.2.6
客户端为
TDengine-client-3.3.6.13-lite
代码
import numpy as np
import pandas as pd
from sqlalchemy import create_engine, text
from sqlalchemy.types import Integer, Float, TIMESTAMP, String
def create_connection_with_sqlalchemy():
    engine = create_engine(f"taos://root:taosdata@192.168.11.225:6030?timezone=Asia/Shanghai")
    conn = engine.connect()
    return conn
conn = create_connection_with_sqlalchemy()
conn.execute(text("CREATE DATABASE IF NOT EXISTS cq"))
conn.execute(
    text(
        """CREATE STABLE IF NOT EXISTS cq.gas_data (datetime TIMESTAMP,p_t FLOAT,p_c FLOAT,q_export FLOAT,p_export FLOAT,temperature_export FLOAT,q_all FLOAT,open_time INT,close_time INT,status INT) TAGS (gas_no BINARY(64))"""
conn.execute(text("Use cq"))
n = 10000
for gas_no in ["aaaa"]:
    tmp_df = pd.DataFrame({
        "datetime": pd.date_range("2025-01-01", periods=n, freq="min"),
        "p_t": np.random.rand(n).astype(float),
        "p_c": np.random.rand(n).astype(float),
        "q_export": np.random.rand(n).astype(float),
        "p_export": np.random.rand(n).astype(float),
        "temperature_export": np.random.rand(n).astype(float),
        "q_all": np.random.rand(n).astype(float),
        "open_time": [120] * n,
        "close_time": [360] * n,
        "status": [1] * n,
        "gas_no": gas_no * n,
        "tbname": gas_no * n,
    column_types = {
        'datetime': TIMESTAMP,
        'p_t': Float,
        'p_c': Float,
        'q_export': Float,
        'p_export': Float,
        'temperature_export': Float,
        'q_all': Float,
        'open_time': Integer,
        'close_time': Integer,
        'status': Integer,
        'gas_no': String,
    tmp_df.to_sql("gas_data", con=conn,
                  index=False, if_exists="append",dtype=column_types, chunksize=100)
    print(len(tmp_df))
错误
原始错误为
使用gdb排查,发现
这是个bug,已经记录。检查下表名长度和数据库名长度是否小于最大值限制
