RED OS 8.0.2
2.6.0.34版本可以在该系统成功部署启动,3.3.6.13安装之后taosd进程无法启动
01/22 14:50:38.054418 00236733 C UTL INFO check global fqdn:tsdb2 and port:6030
01/22 14:50:38.054492 00236733 C UTL INFO [tz]timezone initTimezoneInfo.
01/22 14:50:38.054503 00236733 C UTL INFO total memory size: 32913240KB
01/22 14:50:38.054579 00236733 C UTL INFO mempool taosd opened
01/22 14:50:38.054643 00236733 C UTL INFO memory pool initialized, reservedSize:6428MB, freeAfterReserved:23840MB, jobQuota:0MB
01/22 14:50:38.058775 00236733 C DND INFO start to init dnode env
01/22 14:50:38.059427 00236733 C DND INFO dnode file:/var/lib/taos//dnode/dnode.json not exist
01/22 14:50:38.059610 00236733 C DND INFO mnode file:/var/lib/taos//mnode/mnode.json not exist, reason:No such file or directory
01/22 14:50:38.059615 00236733 C DND INFO deploy mnode required. dnodeId:0<=0, clusterId:0x0<=0, localEp:tsdb2:6030==firstEp
01/22 14:50:38.059623 00236733 C DND INFO file:/var/lib/taos//qnode/qnode.json not exist
01/22 14:50:38.059629 00236733 C DND INFO file:/var/lib/taos//snode/snode0/snode.json not exist
01/22 14:50:38.059648 00236733 C DND INFO file:/var/lib/taos//bnode/bnode.json not exist
01/22 14:50:38.059651 00236733 C XND INFO xnode require call path:/var/lib/taos//xnode, name:xnode
01/22 14:50:38.059707 00236733 C DND ERROR failed to init module at line 571 since Not found
01/22 14:50:38.059717 00236733 C DND ERROR failed to create dnode since Not found
01/22 14:50:38.059720 00236733 C DND ERROR Initialization of dnode failed because your current operating system is not supported. For more information and supported platforms, please visit 支持平台列表 | TDengine 文档 | 涛思数据.
