创建虚拟子表失败语法错误syntax error
ubuntu 22.04
容器部署
【问题复现路径/shan】
执行下列SQL语句
1 创建超级表(执行正常)
CREATE STABLE IF NOT EXISTS pm_kpi.s_pm_measdata (start_time TIMESTAMP, end_time TIMESTAMP, frequency INT, me_value DOUBLE) TAGS (ne_id INT, moi_id VARCHAR(128), me_key VARCHAR(64)) COMMENT ‘PM性能数据表’;
2 创建子表(执行正常)
CREATE TABLE IF NOT EXISTS pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg USING pm_kpi.s_pm_measdata TAGS (10,‘GNB_12353’,‘gnb_cpuavg’);
CREATE TABLE IF NOT EXISTS pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpumax USING pm_kpi.s_pm_measdata TAGS (10,‘GNB_12353’,‘gnb_cpumax’);
3 批量迁移旧表数据到新子表(执行正常)
INSERT INTO pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg (start_time, end_time, frequency, me_value) SELECT start_time, end_time, frequency, gnb_cpuavg FROM pm_kpi.s_measdata_nbs3907d_gnbcpustatic WHERE ne_id = 10 and moi_id = ‘GNB_12353’;
INSERT INTO pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpumax (start_time, end_time, frequency, me_value) SELECT start_time, end_time, frequency, gnb_cpumax FROM pm_kpi.s_measdata_nbs3907d_gnbcpustatic WHERE ne_id = 10 and moi_id = ‘GNB_12353’;
4 创建虚拟超级表(执行正常)
CREATE STABLE IF NOT EXISTS pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (
end_time TIMESTAMP,
frequency INT,
gnb_cpuavg DOUBLE,
gnb_cpumax DOUBLE
) TAGS (ne_id INT, moi_id VARCHAR(128)) VIRTUAL 1;
5 创建虚拟子表(执行失败,语法错误)
CREATE VTABLE IF NOT EXISTS pm_kpi.vt_measdata_nbs3907d_gnbcpustatic_10_GNB_12353 (
end_time TIMESTAMP FROM t_pm_measdata_10_GNB_12353_gnb_cpuavg.end_time,
frequency INT FROM t_pm_measdata_10_GNB_12353_gnb_cpuavg.frequency,
gnb_cpuavg DOUBLE FROM t_pm_measdata_10_GNB_12353_gnb_cpuavg.me_value,
gnb_cpumax DOUBLE FROM t_pm_measdata_10_GNB_12353_gnb_cpumax.me_value
) USING pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) TAGS (10,‘GNB_12353’);
第 5 步创建虚拟子表时报告执行失败,语法错误
错误信息:
SQL 错误 [9728]: TDengine ERROR (0x2600): sql: CREATE VTABLE IF NOT EXISTS pm_kpi.vt_measdata_nbs3907d_gnbcpustatic_10_GNB_12353 (
end_time TIMESTAMP FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.end_time,
frequency INT FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.frequency,
gnb_cpuavg DOUBLE FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.me_value,
gnb_cpumax DOUBLE FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpumax.me_value
) USING pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) TAGS (10,‘GNB_12353’), desc: syntax error near “using pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) tags (10,‘GNB_12353’)”
好的 我们看下
根据语法,
虚拟子表不需要指定列类型。
我试过不加类型也是语法错误,比如改为如下语句
end_time **FROM** pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.end_time,
frequency **FROM** pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.frequency,
gnb_cpuavg **FROM** pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.me_value,
gnb_cpumax **FROM** pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpumax.me_value
start_time **FROM** pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.start_time,
end_time FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.end_time,
frequency FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.frequency,
gnb_cpuavg FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpuavg.me_value,
gnb_cpumax FROM pm_kpi.t_pm_measdata_10_GNB_12353_gnb_cpumax.me_value
) USING pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) TAGS (10,‘GNB_12353’), desc: syntax error near “from pm_kpi.t_pm_measdata_10_gnb_12353_gnb_cpuavg.end_time,
frequency from pm_kpi.t_pm_measdata_10_gnb_12353_gnb_cpuavg.frequency,
gnb_cpuavg from pm_kpi.t_pm_measdata_10_gnb_12353_gnb_cpuavg.me_value,
gnb_cpumax from pm_kpi.t_pm_measdata_10_gnb_12353_gnb_cpumax.me_value
) using pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) tags (10,‘GNB_12353’)”
按照陈老师指导,去掉类型去掉时间戳列start_time后,创建成功了,感谢陈老师支持。
修改后正确的sql如下:
) USING pm_kpi.vs_measdata_nbs3907d_gnbcpustatic (ne_id, moi_id) TAGS (10,'GNB_12353');
