taosdump 必须在启动下才能备份数据么
taosdump 必须在 taosd 正常运行时才能工作,你现在是什么版本,要升级到什么版本?一般来说,可以通过拷贝数据目录的方式做全量备份
3.0.0.1 升级到3.6.6.13版本 能直接copy /var/lib/taos 下面的文件?
不能,这个版本太旧了,和现在不兼容。
有什么方式可以使数据库重启起来么? 现在起不来了,taosdump无法使用。 centOS 单节点 目前报错是:10:14:49 localhost systemd: Starting TDengine server service…
Oct 9 10:14:49 localhost systemd: Started TDengine server service.
Oct 9 10:14:50 localhost kernel: vnode-apply[11943]: segfault at 1428 ip 00007f4260287d29 sp 00007f41e37dff98 error 4 in libc-2.17.so[7f4260133000+1c4000]
Oct 9 10:14:50 localhost systemd: taosd.service: main process exited, code=killed, status=11/SEGV
Oct 9 10:14:50 localhost systemd: Unit taosd.service entered failed state.
Oct 9 10:14:50 localhost systemd: taosd.service failed.
Oct 9 10:14:50 localhost systemd: taosd.service holdoff time over, scheduling restart.
Oct 9 10:14:50 localhost systemd: Stopped TDengine server service.
Oct 9 10:14:50 localhost systemd: Starting TDengine server service…
Oct 9 10:14:50 localhost systemd: Started TDengine server service.
Oct 9 10:14:50 localhost kernel: vnode-apply[12044]: segfault at 0 ip 00007f6cbf2e5cb5 sp 00007f6c537c9f98 error 4 in libc-2.17.so[7f6cbf191000+1c4000]
Oct 9 10:14:51 localhost systemd: taosd.service holdoff time over, scheduling restart.
Oct 9 10:14:51 localhost systemd: Stopped TDengine server service.
Oct 9 10:14:51 localhost systemd: Starting TDengine server service…
Oct 9 10:14:51 localhost systemd: Started TDengine server service.
Oct 9 10:14:51 localhost kernel: vnode-apply[12150]: segfault at 0 ip 00007f3b50660cb5 sp 00007f3ad4fcaf98 error 4 in libc-2.17.so[7f3b5050c000+1c4000]
Oct 9 10:14:51 localhost systemd: taosd.service: main process exited, code=killed, status=11/SEGV
Oct 9 10:14:51 localhost systemd: Unit taosd.service entered failed state.
Oct 9 10:14:51 localhost systemd: taosd.service failed.
Oct 9 10:14:51 localhost systemd: start request repeated too quickly for taosd.service
Oct 9 10:14:51 localhost systemd: Failed to start TDengine server service.
3001 起不来了吗? 微信沟通吧 a15652223354
需具体排查,如遇相同问题,请重新发帖。
