目前在测试环境k8s上面进行试用部署
k8s容器部署
在k8s通过自己创建或yaml文件部署
yaml文件:
kind: Pod
apiVersion: v1
metadata:
generateName: vt-tdengine-7b97484667-
namespace: vt-gwm
labels:
app: vt-tdengine
pod-template-hash: 7b97484667
annotations:
kubesphere.io/creator: ld.zhang
kubesphere.io/imagepullsecrets: ‘{}’
kubesphere.io/restartedAt: ‘2025-11-19T09:13:09.237Z’
logging.kubesphere.io/logsidecar-config: ‘{}’
tke.cloud.tencent.com/networks-status: |-
“name”: “tke-route-eni”,
“interface”: “eth0”,
“ips”: [
“172.21.32.82”
“mac”: “92:80:bb:32:f0:a7”,
“default”: true,
“dns”: {}
spec:
volumes:
- name: tdengine-data
hostPath:
path: /data/tdengine
type: ‘’ - name: kube-api-access-mlzcd
projected:
sources: - serviceAccountToken:
expirationSeconds: 3607
path: token - configMap:
items: - key: ca.crt
path: ca.crt - downwardAPI:
items: - path: namespace
fieldRef:
apiVersion: v1
fieldPath: metadata.namespace
defaultMode: 420
containers: - name: tdengine
image: ‘harbor.bluesphere.cloud/vt-gwm-tdengine/tdengine:latest’
ports: - name: taosd
containerPort: 6030
protocol: TCP - name: rest
containerPort: 6041
protocol: TCP - name: https
containerPort: 6043
containerPort: 6044
protocol: TCP
env: - name: TAOS_CFG_VNODE_NUM
value: ‘1’ - name: TAOS_CFG_MAX_VNODE_NUM
value: ‘2’ - name: TAOS_CFG_MAX_CONNECTIONS
value: ‘500’ - name: TAOS_CFG_HTTP_ENABLE
value: ‘1’ - name: TAOS_CFG_CACHE
value: ‘128’ - name: TAOS_CFG_BUFFER
value: ‘256’ - name: TAOS_CFG_PAGES
value: ‘128’
resources:
limits:
cpu: ‘2’
memory: 8Gi
tke.cloud.tencent.com/eni-ip: ‘1’
requests:
cpu: ‘1’
memory: 4Gi
volumeMounts: - name: tdengine-data
mountPath: /var/lib/taos - name: kube-api-access-mlzcd
readOnly: true
mountPath: /var/run/secrets/kubernetes.io/serviceaccount
terminationMessagePath: /dev/termination-log
terminationMessagePolicy: File
imagePullPolicy: IfNotPresent
restartPolicy: Always
terminationGracePeriodSeconds: 30
dnsPolicy: ClusterFirst
serviceAccountName: default
serviceAccount: default
nodeName: 172.21.64.4
securityContext: {}
schedulerName: default-scheduler
tolerations: - key: node.kubernetes.io/not-ready
operator: Exists
effect: NoExecute
tolerationSeconds: 300 - key: node.kubernetes.io/unreachable
operator: Exists
effect: NoExecute
priority: 0
enableServiceLinks: true
preemptionPolicy: PreemptLowerPriority
现象:
通过taosd启动后的命令行打印的:
1/20 09:29:06.343575 00005200 C UTL INFO check global fqdn:localhost and port:6030
11/20 09:29:06.343724 00005200 C UTL INFO total memory size: 16125724KB
11/20 09:29:06.343774 00005200 C UTL INFO memory pool disabled since no enough system available memory after reservied, size: 3845865472
11/20 09:29:06.343786 00005200 C DND INFO start to init dnode env
11/20 09:29:06.344171 00005200 C DND INFO succceed to read dnode file /var/lib/taos/dnode/dnode.json
11/20 09:29:06.344227 00005200 C DND INFO succceed to read mnode file /var/lib/taos/mnode/mnode.json
11/20 09:29:06.344232 00005200 C DND INFO deploy mnode required. option deploy:1
11/20 09:29:06.344237 00005200 C DND INFO file:/var/lib/taos/qnode/qnode.json not exist
11/20 09:29:06.344242 00005200 C DND INFO file:/var/lib/taos/snode/snode.json not exist
11/20 09:29:07.344464 00005200 C DND ERROR failed to lock file:/var/lib/taos/.running since Resource temporarily unavailable, retryTimes:1
11/20 09:29:08.344578 00005200 C DND ERROR failed to lock file:/var/lib/taos/.running since Resource temporarily unavailable, retryTimes:2
容器日志打印的:
0.000000, 0.167261, 0), error:Post “http://localhost:6041/rest/sql/log?req_id=3333272583926713447”: dial tcp 127.0.0.1:6041: connect: connection refused
2025-11-19T20:24:45.963406778+08:00 /usr/bin/entrypoint.sh: line 126: 4354 Killed taoskeeper
2025-11-19T20:26:03.772735029+08:00 /usr/bin/entrypoint.sh: line 135: 4375 Killed taos-explorer
2025-11-19T20:36:45.340809198+08:00 + true
2025-11-19T20:36:45.340834659+08:00 + sleep 1000
2025-11-19T20:53:25.342410662+08:00 + true
2025-11-19T20:53:25.342443905+08:00 + sleep 1000
自己都将这些问题问了AI:按照AI给的解决方案,执行了这些操作:
ps -ef | grep taosd
pkill -9 taosd
ls -l /var/lib/taos/.running
rm -f /var/lib/taos/.running
taosd再次启动后,能正常启动一会儿,然后6030 6041 6044端口又自己停了
