使用tdgpt的forcast功能报TDengine ERROR (0x445): Analysis failed since anode return error
 3.3.6(tdgpt版本同为3.3.6)
 CentOS Linux release 7.9.2009 (Core)
docker容器部署
无法使用tdgpt的数据预测功能
使用tdgpt的预测分析功能,即sql里使用FORECAST函数时报错(arima、tdtsfm_1等算法 ):
TDengine ERROR (0x445): Analysis failed since anode return error,
能正常使用tdgpt的异常检测功能(ANOMALY_WINDOW)
详细报错日志如下:
org.jkiss.dbeaver.model.sql.DBSQLException: SQL 错误 [1093]: TDengine ERROR (0x445): Analysis failed since anode return error
	at org.jkiss.dbeaver.model.impl.jdbc.exec.JDBCStatementImpl.executeStatement(JDBCStatementImpl.java:130)
	at org.jkiss.dbeaver.ui.editors.sql.execute.SQLQueryJob.executeStatement(SQLQueryJob.java:657)
	at org.jkiss.dbeaver.ui.editors.sql.execute.SQLQueryJob.lambda$2(SQLQueryJob.java:550)
	at org.jkiss.dbeaver.model.exec.DBExecUtils.tryExecuteRecover(DBExecUtils.java:189)
	at org.jkiss.dbeaver.ui.editors.sql.execute.SQLQueryJob.executeSingleQuery(SQLQueryJob.java:569)
	at org.jkiss.dbeaver.ui.editors.sql.execute.SQLQueryJob.extractData(SQLQueryJob.java:1043)
	at org.jkiss.dbeaver.ui.editors.sql.SQLEditor$QueryResultsContainer.readData(SQLEditor.java:4536)
	at org.jkiss.dbeaver.ui.controls.resultset.ResultSetJobDataRead.lambda$0(ResultSetJobDataRead.java:128)
	at org.jkiss.dbeaver.ui.controls.resultset.ResultSetJobDataRead.run(ResultSetJobDataRead.java:126)
	at org.jkiss.dbeaver.ui.controls.resultset.ResultSetViewer$ResultSetDataPumpJob.run(ResultSetViewer.java:5161)
	at org.jkiss.dbeaver.model.runtime.AbstractJob.run(AbstractJob.java:119)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.sql.SQLException: TDengine ERROR (0x445): Analysis failed since anode return error
	at com.taosdata.jdbc.TSDBError.createSQLException(TSDBError.java:95)
	at com.taosdata.jdbc.ws.WSStatement.execute(WSStatement.java:94)
	at com.taosdata.jdbc.ws.WSStatement.execute(WSStatement.java:75)
	at org.jkiss.dbeaver.model.impl.jdbc.exec.JDBCStatementImpl.execute(JDBCStatementImpl.java:344)
	at org.jkiss.dbeaver.model.impl.jdbc.exec.JDBCStatementImpl.executeStatement(JDBCStatementImpl.java:128)
	... 12 more
关于TDgpt ,建议先使用最新版 3.3.7.5,修复了一些初始版本的问题。
然后基于新版本我们再做调试
